shower wired in swa? | on ElectriciansForums
Discuss shower wired in swa? in the UK Electrical Forum area at ElectriciansForums.net
M
Mike Blair
Alright guys got a phone call of a friend asking me to do a shower...but the client doesn't want conduit or the walls to be chased out. The ferm and the client agreed with a swa from the db clipped outside into the loft then into isolator and shower.... Is this even ok?? ignore the fact its gona be ugly as .... what do you guys think?
It won't be ugly if you take a bit of pride in the job and do it properly.
As long as you have a sensible plan to gland the SWA at the isolator then I can't see what's wrong with it, what is your concern?
But why SWA?
once connected a shower for a customer who'd installed 6mm T/E up the outside of his house. this was 25 years ago, and it's still almost as good as when it was installed. so what happened to UV degradation?
Is it on the north side of the house... T&E (depending on manufacturer) usually degrades quickly in direct sunlight, I have seen it whiten and crack cables south facing within a few years.. again depends on manufacturer but its not a UV tolerant cable so shouldn't be used unless stated so by the manufacturer.
Reply to shower wired in swa? in the UK Electrical Forum area at ElectriciansForums.net
