Nicelectrician: You wrote in your first post:
We use a normal 4x1.5mm cablet (3power 1ground).
by which I understand you provide L1, L2 and L3 and an earth/cpc to the autoclave.
But the image you show of the RCCB shows L1, L2, L3
and a neutral - to the far right of the four terminals top and bottom - there is a black conductor going in and not out. This indicates to me that the autoclave requires a four wire 3 phase supply - L1, L2, L3 and N plus an earth/cpc.
The fact that the RCCB trip test button does not work also
indicates the N is absent.
I think then that you should check the installation instructions to confirm whether a Neutral is required - because I reckon it most certainly is.
At the stage of the autoclave process, the sterilisation has been completed and the chamber and its contents are now being rapidly cooled by a number of cycles of vacuum pump on, vacuum pump off(hold), vacuum pump on, VP off(hold)... see:
Every research facility is interested in improving their overall autoclave efficiencies. Here, we explore the steam sterilization cycles: Rapid Cool Cycles.
consteril.com
If the autoclave uses a water cooled cooled jacket system to reduce the the chamber temperature, there is either a small water pump being turned on/off to circulate cold water or an electrically operated solenoid valve is opening/closed to do it. The pump or valve may be the only electrical part of the autoclave which require a Neutral. The absence of the supply neutral only becomes a problem then the first time they are energised by the autoclave's computer/controller.
(For my EF colleagues, I suspect there are other light current loads using a neutral, the net effect being a virtual neutral is produced which is good enough for them until the higher current required by the pump/solenoid I mentioned in the previous paragraph disturbs its potential wrt the lines and earth and then transient leakage currents trip the RCCB or the residual current over the 3Ls and N through the RCCB sense coil - the virtual N being on the load side of the RCCB -or something along these lines.)
