Hi there. I am attempting to install a dimmer switch to replace the current one-way flip switch. The switch turns on/off simple ceiling rose.
On the dimmer switch have matched the RED Common wire and the black wire to L1 as the flip switch had it. The metal box is grounded.
However, after installation, the dimmer switch (or is it the ceiling light?) behaves erratically. Sometimes it will turn on, sometimes not. Other times it does come on, the light flickers and sometimes not. This has happened with 2 different dimmers.
Can I assume I do not have the right bulb in the rose? The load is wrong for the dimmer?
