Single & 3-Phase Voltage in The UK
P
pprendeville
Hi all,
Just a quick question on single phase and 3-phase voltage.
Do The UK use 240V Single Phase and 415V 3-Phase?
We are now 'harmonised' with Europe and theoretically the voltages in the UK are 230 V single phase and 400 V 3 Phase.
Indeed, all of the relavent tables in BS 7671 (The 17th Ed Regs), are now calculated to 230 V. Examples of this can be seen in the Maximum Earth Fault Loop Impedance Tables in Chapter 41.
When we measure voltages in the UK the values are typically higher as quite correctly stated in a previous post.
But don't Panic - this makes thing safer as we have lower earth loop values to meet.
Incidentally, the only place that I know (there may be others) where you get a true 230/400 V is some of the ASDA stores!
So now you know - Hope this helps.
So a voltage in a company/factory like jaguar etc the voltage is 400v?
This is a 6yr old thread but as you ask then Yes! between phases 400v and as usual any phase to N/E will be 230v.
Larger factories or heavier industry may even have higher voltage systems to distribute around large sites but for the general jist the 3ph supplies are the norm in factories and large commercial.
Note not every factory etc has 3ph some only 1ph especially the smaller units.
It is a bit illy how everything is based on something that's incorrect or not what it's supposed to be.
Nothing is how its is supposed to be... Politicians are meant to look after the people but they are a bunch of liars. Companies say they are looking after their customers and employees when they are really just concerned about profit.... That's my Wednesday whinge over with.... grumpy man out.....
400/230 is no more silly than brown/black/grey. 1 is as stupid as the other.
We have our own tranny and the tap it's set on with the 11kv coming in gives us 418/248 volts
Disagree. A small change in nominal voltages (c 1%) for no good reason is silly. The harmonised colour change is utter insanity.
The supply voltage in the UK is 230v with a tolerance of +10% -6% which meant that when we harmonised with Europe the supply companies could still pump out 240v.
Why do you say that the harmonised colour change is utter insanity?
pprendeville,
sysrq,
