Single Electric Oven new installation | Page 2 | on ElectriciansForums
Discuss Single Electric Oven new installation in the DIY Electrical Advice area at ElectriciansForums.net
they're busy today on another job:
[ElectriciansForums.net] Single Electric Oven new installation
There is a big chance that the Indesit "installers" will not be touching any hard-wired stuff. They are not electricians.
And that's a risk that they won't take the old one away.
To the OP see if you can pull the cooker out a little and look down the back. If you see the cable go into the wall without a standard plug then you need an electrian in to disconnect your cooker. If landlord approves get telectrix in Wednesday afternoon to do that and fit socket out in place for your delivery and install on Thursday. Installers can then remove your old one for recycling without excuse.
Just to inform you, problem solved, today indesit staff were able to install the new oven and everything works fine!
Thanks Telectrix!
Reply to Single Electric Oven new installation in the DIY Electrical Advice area at ElectriciansForums.net
Hi thanks for the reply, it is definitely 10mm2 as can see it written on the outer. It goes through the roof rafters with no insulation and then...
I believe the 6mm and 40A MCB debate is a little contentious at times. It depends on the installation method, being pretty close to the tabulated...
