Installed a garage CU, 2 way. As the house is TNC-S an earth rod has been installed, which is giving an Ra of 102 ohms.
The supply to the garage is protected by a MCB on the non RCD side of the CU, as installation methods don't require RCD protection.
The circuit in the garage has been protected by a 30ma type B RCBO. It is only single pole. I have today been told that it has to be of the double pole kind. Have I messed up?
