Single phase motor humming and heating up. | on ElectriciansForums
Discuss Single phase motor humming and heating up. in the Electrical Engineering Chat area at ElectriciansForums.net
i=p/u
Northern Ireland
Hi, morning EF.
I was looking at a single phase motor yesterday attached to hydraulic pump for cardboard bailing machine that seems to be temerpemental with stop and starting and making humming sound.
I checked the contactor was working first and voltage was going to motor, I clamped the cable and was getting full current, with the motor not starting and humming and heating up very quickly. I just stopped and turned off so couldn't be used or touched.
I've just priced new motor and hydraulic pump and on reading further and thinking a little further, the capacitor is used as second phase to start up and then cuts off when running. I'm starting to think could the capacitor cause this and not even need new motor and pump.
Thx Trev.
[ElectriciansForums.net] Single phase motor  humming and heating up.[ElectriciansForums.net] Single phase motor  humming and heating up.[ElectriciansForums.net] Single phase motor  humming and heating up.few pics.. well there we go, rating plate says 8.3A but when I clamp it, I'm getting 15 odd Amps which would suggest capacitor has kicked in, and with motor not starting not dropping down to the current rating.. hmmm..[ElectriciansForums.net] Single phase motor  humming and heating up.
Can you get the fan cover off or otherwise see if the motor is mechanically locked or stiff?
A failed capacitor might explain the effect if the motor is free enough to rotate.
Bog standard symptom of failed capacitor. Of course failed capacitor can mean failed windings too but hopefully it hasn't got that far.
Well new motor and hydraulic pump came today, swapped it over, but now the up/down controls are not working, it will only go down if I hold in the contactor... so much for simple.swap [ElectriciansForums.net] Single phase motor  humming and heating up.[ElectriciansForums.net] Single phase motor  humming and heating up.
If you tell me the make and model of the machine I will research a manual for it.
Which is the compress bail direction - up or down?
I did a quick google to learn more about compactors and turned up a wiring diagram for one made by the Philadelphia Tramrail Company. It has two modes of operation viz 'start auto' and 'start reverse'. The first I think does a complete compress after initiation and then returns back to park cycle automatically whereas the second mode (I think) is a 'dead man's handle' control scheme only operating to reverse while a button is pressed and all safety interlocks are good. I am not saying the PTR product is how your bailer works but often products have similar features and control logic. You can see for example 2 solenoids for up and down hydraulic flow - REV SOL and FOR SOL.
So, some more information would be useful and a picture of the control pushes/switches.
Stationary Compactor Schematics (1/2) - https://parts.ptrco.com/product-p/stationary-schematics.htm
I believe this is a single phase one way rotation and the up and down is controlled by fluid link solenoid..
I think I might have the solenoid in the wrong hole at the top and need adaptors for the side entrance which is marked trv - 08.[ElectriciansForums.net] Single phase motor  humming and heating up.
The motor of your machine only rotates in one direction. The up/down is controlled by solenoid controlled hydraulic valves. There are not enough wires going to the motor terminal box to reverse its direction using the control panel.
We need a reference document for details on how it is designed, built and meant to work for further progress; we cannot dabble with machinery.
I got guy out from company who supplied the motor and he said there was a spring missing from the port which had valve saying tv-8.. who knows, working now for a fee plus millage.
Reply to Single phase motor humming and heating up. in the Electrical Engineering Chat area at ElectriciansForums.net
    • Friendly
Have you got the lid of the connection box on the motor? Often there's a wiring diagram inside the lid. What is the make and model number of the...
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
