Single RCD board - changed to dual RCD board? | Page 2 | on ElectriciansForums
Discuss Single RCD board - changed to dual RCD board? in the Australia area at ElectriciansForums.net
H
highspark
I want to encorporate an extra RCD into a single RCD board as you will know my problem is the neutral bars. In the present single RCD board there is only 2 neutral bars. If I was to change it I'd need to split one of the neutral bars into a 3rd for the outgoing neutrals of each RCD? Would this be bad practice in your eyes lads? It's either a separate dual RCD board. Or A small garage unit. Or split one of the neutral bars
Hi High spark,
If you split the neutral bar, how would you fit/attach it in the board? Can you not use the other neutral bar (non rcd side) and any circuit on that bar, put on the new rcd? Or is it being used?
Cheers
Jay
Can't do it mate because both outgoing neutrals from both RCD's will be on the same bar an it will cause problems back currents etc
Most boards have little plastic contraptions to click the earth and neutral bars in place
Its a simple job if you get a spare bar,shorten them all to suit, and another clip it in thing
Topquark has given the same advise that I agree with
Rcbo
Reply to Single RCD board - changed to dual RCD board? in the Australia area at ElectriciansForums.net
What makes it a lack of space? I’d say to the customer to dismantle a cupboard or whatever to creat the space you need for the extra equipment...
