Single to 3 phase converter | Page 2 | on ElectriciansForums
Discuss Single to 3 phase converter in the UK Electrical Forum area at ElectriciansForums.net
London
Hi All,
I'm after a little help/advise from anyone who has any knownledge or experience in a single to 3-phase inverters.
My scenario:
We're in the final process of finishing a care home rewire, they have a 3-phase lift being installed. Everything's in place and been ran etc...
UK power networks has just given the owner a quote of over 100k to upgrade the current supply to a 3-phase supply to accommodate the 3-phase lift.
Has anyone ever fitted a 3-phase inverter? The installation currently has a 100amp supply but the loading is minimal. The lift is 31.7amps (37.8amps start up). Can I supply a 3-phase inverter with a 6mm 40amp MCB from my single phase and then supply the lift that way.
Has anyone ever installed one before? Recommendations or advise is much appreciated.
It is correct that a lift for general use could be incorporated into an escape plan in an emergency situation after a risk assessment and a controlled strategic plan but generally this would be considered a high risk policy. Lifts which have been put in place as part of an escape route are subject to strict legal requirements and are generally only considered where vertical footfall is not free flowing such as a hospital where mobility may be restricted.
The motor is rated at under 12kW.
You can use a 1ph - 3ph VFD to control just a 3ph motor. The existing controls would be wired to the VFD controls, fairly simple if you understand the way the lift works and safety requirements etc.
But will the lift company want/know how to redesign their lift for a one off project?
No.
Reply to Single to 3 phase converter in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
