Size of incoming mains cable? | on ElectriciansForums
Discuss Size of incoming mains cable? in the UK Electrical Forum area at ElectriciansForums.net
C
craigj85
What is the general size of a incoming mains into a small 3 bedroom house? The main fuse is 60 amp. The enclosure where the mains splits and goes to the main switch is sealed and crimped so couldn't look but the tails look to be 16/25mm. Sorry I don't have a pic as a big cupboard was built around the mains and cu
Reply to Size of incoming mains cable? in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
If your using 35mm or 50mm use 2 core SWA and use the armour as the earth, it'll cut down on price. I know people will comment on this but the...
