Sizing power cables part installed in ducts | Page 2 | on ElectriciansForums
Discuss Sizing power cables part installed in ducts in the Talk Electrician area at ElectriciansForums.net
Parallel cables whether two or three of them maybe the best option as you will get a reduced overall csa.
Would imagine its reference method D in the tables then do your correction factors Cs,Cc,Cd and whatever else is appropriate
Reply to Sizing power cables part installed in ducts in the Talk Electrician area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
I have a bar light that the bulbs burned out. It had E11 bulbs with .1watt each with a 2 batties with double AA in it to run. I am looking at...
