Sky and telephone points | Page 2 | on ElectriciansForums
Discuss Sky and telephone points in the UK Electrical Forum area at ElectriciansForums.net
Livingston
Doing a rewire and need to sort a couple of sky points and reroute the BT master point, haven't done it before, few questions I would appreciate some help with.
1) need to run sky cable to 2 points, is rg6 the cable I need?
2) is standard 4 pair telephone cable ok for the bt master point?
3) there is a few bt points in the house, how do I find out what one is the master and how do I extend this to move it to another location? All the cable is to be under the floor so would be looking to join the incoming bt cable and extend it under the floor, so a junction of some sort under the floor as it isn't long enough to reach the position it is needed.
Thanks in advance!
Wifi or Ethernet for the multi room boxs, the Main box still needs a twin feed.
Am I correct in thinking that new Sky boxes don't allow a 9 or 12V phantom power output to allow for a magieye? And if so, is the only alternative forking out for multiroom?
The new box doesn't support any magic-eyes or have any rf outputs the best solution if you don't want to pay sky for additional boxes would be to split the hdmi output and use an ir injector.
Cheers fisher. Here's hoping my 5+ year old sky plus box lasts another 10 years then! Although saying that, it will prob be all WiFi then in 4K.
Reply to Sky and telephone points in the UK Electrical Forum area at ElectriciansForums.net
Neither did I. 44 to 57V according to IEEE 802.3af apparently. It's "active PoE" and the supplying unit handshakes with the receiving unit...
    • Winner
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
