Slow insulation resistance? | on ElectriciansForums
Discuss Slow insulation resistance? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
whazza22
Carried out an insulation resistance test on two lighting circuits today and both circuits the reading was very slow.
It started about 200Mohms and gradually goes up in tens, and stops on 400Mohms:(
Normally the meter shoots straight to >1000
Any ideas?
at 200 meg, its well above requirement . are you sure all lamps are out?
Any ideas?
That can be a sign of dampness but as Telectrix says, you're miles in at 200 to 400 Million Ohms!
All lamps were defo removed and I disconnect the ballast from fluroscent fitting.
Cables were in connector blocks when testing.
Assuming meter batteries are ok it appears to be something capacitive charging up, not pyro/FP type cable by any chance? since these can charge.
[Capacitor = two conductive surfaces with insulator between, just like above cable types].
Reply to Slow insulation resistance? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
I may have been mistaken regarding TT I will look into that, thank you for the valued reply, but in general I stick to my post, a good topic for...
