SMA final comply!!! | on ElectriciansForums
Discuss SMA final comply!!! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
nickos1986
SMA are now birthing the 4000TL with settings that apply under G59 so when installing a 3.9 pv system all that needs to shown to the DNO is a certificate because the inverter is deemed to automatically comply with regulations and no further tests are required.
Anybody need a copy of the certificate let me know.
How do you go about this issue then when applying to the DNO do you have them witness the installation or do they just accept the certificate
Reply to SMA final comply!!! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
