This thread titled "sma sunnyboy" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
sedgy34
got an sma 4000tl20 doing a 4kw, set at G59 need to change it to G83 "high grid voltage"ive had permission from DNO how do i do this without calling sma (as they are closed) for the weekend
got bluetooth device connected etc
you need a grid guard code, then IIRC it's in setting >> AC or settings >> grid monitoring
something like that anyway
email or call sma for a grid guard code once they give it to you change the setting on the sunny boy via bluetooth from sunny explorer
Reply to the thread, titled "sma sunnyboy" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
