small plung circular saw | on ElectriciansForums
Discuss small plung circular saw in the UK Electrical Forum area at ElectriciansForums.net
sunny essex
I have come to the stage where lifting floorboards by hand saw and bolster is hard work , i have used large circular saws but found them to clumsy are small plung circular saws any good for cutting tongue and groove floor boards for lifting ???
I've got a small ÂŁ20 circular saw i use for cutting the tongue's out of floorboards i got from the nasty orange shed, cna set the depth an' all so allsgood.
Plunge saws tend to be expensive.
To check the depth I have in the past drilled a 10mm hole in an obscure place, normally the corner of the room to avoid most cables and pipes, then used a piece of coat hangar wire with a small 90 degree bend in it to drop through and then pull up flush against the bottom of the board. Mark it with a pen, withdraw and measure the depth of the board.
Most modern houses you can pretty much guarantee the depth of board however I have found boards up to 1 1/2 inches on older properties. Just set the circular saw a mm or so shallower and haven't hit a pipe or cable yet, if the cut isn't quite deep enough can then run along it with the good old Stanley knife.
you dont need a plunge saw for this richard....just set the depth of the blade to the same hight as board thicknes....then introduce the blade to the board gradually whilst the saw is running....this is how we do it and it works fine.....in fact you can use a fein as well to get the bit near skirting boards etc that the circular saw cant reach.....just go steady....you dont need a big saw for this kind of work either....
a 7 1/2" blade one is OK....we have an hitachi....
Reply to small plung circular saw in the UK Electrical Forum area at ElectriciansForums.net
I doubt we would be recommending them if they were not up to the job
C
Small rental portfolio advice please. With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency...
Chris Taylor
C
