naylorpd
I'm building a house in Azerbaijan, with 3 phase mains supply and TT earthing. The main transformer is at least 800m from my house. Whilst doing my final measurements before going live, I noticed a small voltage between neutral and earth. It varies between 2-4V and seems to be AC. It isn't a stable voltage, it seems that each time I connect the meter probe the voltage is very slightly different, but so far never above 4V.
It dosn't seem like I can do anything about this, my own earth tested OK after I installed it and the earthing of the neutral line at the transformer is what it is - probably not as good as mine.
In case it's relevant, the incoming 3 phase is on aluminium cable, but once it reaches my property everything is 100% copper.
Do I need to worry about this?
Philip
Philip
