Smallest possible cable for a 4w LED load. | Page 2 | on ElectriciansForums
Discuss Smallest possible cable for a 4w LED load. in the Lighting Forum area at ElectriciansForums.net
I know I am harping on here but I cannot see a method for doing that in a compliant manner whether it is used once, twice a year or whether an rcd is involved.
Small point but its 1a total load. And LED have high draw current. And why dont you just use the existing cable as a matter of interest?
Eh? Neglecting power factor, it's less than 0.02A per lamp. I guess the new wire (if required) will be partly on the outside of the fitting and accessible, so having the required insulation properties and robustness will be the defining factors.
Cheers guys, I have just kept the original wiring other than the main flex. I've replaced dodgy connectors with slightly less dodgy crimps. I devised a cable clamp on the incoming flex also. It's as safe as i can sensibly make it
I found an Inline dimmer with a min load of 11W so it should work to about half light. Really impressed with the 4W filament LED lamps, they don't even get hot to the touch but they are very bright and i think the dimmer will be appreciated...
How have you enclosed the crimps.
Probably a lot safer now than when it was first made. Candles were a major source of house fires. There you go a positive reply!
I'd rather not thanks, you will just tell me that it's inadequate
I believe you would have got an honest review of the work you have done. good or bad would depend on the way it was done.
Can't be worse than the original tape and chock blocks?
[ElectriciansForums.net] Smallest possible cable for a 4w LED load.
Lets not get all bitchy now. It's the season of good will and kissing under the mistletoe.
Reply to Smallest possible cable for a 4w LED load. in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
