Smart switch buzz ☹️ | on ElectriciansForums
Discuss Smart switch buzz ☹️ in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hi folks, need a little advice,
I have brought a smart switch, 1 gang 1 way, this is controlling 1 light in the bedroom, I have no nutural at the switch, live in and live out, it came with a capacitor that I have installed at the light, neutral and live on the light side, everything works fine but I’m getting a faint buzz from the switch. This is not a dimmer and have a normal 5w led bulb.
any ideas what’s causing the buzzing and how to stop it.
thanks guys for your help.
Reply to Smart switch buzz ☹️ in the UK Electrical Forum area at ElectriciansForums.net
My guess from that last picture is the whoever installed it has drawn two 6242Y’s instead of a single 6243Y for the 2way side of that two gang...
Everything worked perfectly—thank you so much for your guidance! I followed your advice and isolated the supply permanent live in the Wago...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
Thanks I used the proper cable, similar to the one used for wiring the switch (grey tough one)
