Smashed it !!! what a result in June so far | on ElectriciansForums
Discuss Smashed it !!! what a result in June so far in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Heywood Lancs
Check this system out
Trina 235w x 17
Solar edge SE4000 and 17 x Power optimizers
south facing
Aberdeen scotland NOTE READING FOR 20th MAY ..... 29.32 KWH in one day WOW WEEEEEEEEEEEEE has any body witness higher than that ? [ElectriciansForums.net] Smashed it !!! what a result in June so far 424 kwh already in MAY ................ the owner must be over the moon I think I will ring him.
that is good (May, you mean May-calm down)
This is why we are offering the solar edge systems now.
Do you know why the solar edge report gives an annual yield in Mwh and not kwh?
Obviously scotland has had lots of sun dispite the cold weather, this has helped the panel output significantly, unlike the other end of the country where it has just been cloudy and wet.
And if I come across as jealous- I flippin well am!!!
We have been installing solar edge since Jan 2011 and installed around 70-80 solar edge systems now .
heres an install down south just outside of London ...
less than above but still good for 23 days worth .....
That's really good and puts my last 3 days of 27.76kWh, 28.05kWh and 27.56kWh in the shade a little!
Just under 385kWh so far this month (23days) though the recent weather has been excellent.
I'm now wondering if the 30kWh barrier can be broken?
Yes, the weather here has been the worst ever since records began in the 1800's for cool, wet and cloudy. It's normally bright, sunny and dry here.
In fact, it's so cold and wet recently that Scotland is warmer, sunnier and drier. Quite a lot of the plants and trees round here are very sick due to lack of sun.
The lawns and tree leaves round here are more yellow than green due to lack of sunlight (just as grass goes yellow if it is covered for a few days).
I've actully just had two of my apple trees have all their leaves shrivel-up and die, with the tree suddenly dying too. I have another couple of apple tree looking very sick, and have noticed quite a few other trees in the area have died. No specific disease; just not enough sun to keep their photosynthesis going.
Having been in holidaying in the New Forest recently, it was quite a shock to come back from a run of glorious, clear sunny days to find heavy cloud cover and mist hanging over Essex and East Anglia.
However, my wife informs me that the Gulf Stream (or something similar to it) has been knocked a bit off its usual path in recent months, and that's why the weather in some parts of the UK is not normal. It's just a case of waiting for the Gulf Stream to revert back. In reverting back, it'll probably overshoot in the other direction, perhaps turning the weather cold and dull for other parts of the UK.
But as it stands, the SouthEast and East Anglia are really suffering from lack of sun at the moment.
Check out Uncle Mike Dundee on PVoutput - admitting to 34.32Kw on 22/5 from 3.75KWh system
No, Don,t bother, his count started at 16kW for the day
Brilliant - all that extra daylight pays off up there :)
34kw - unbelievable - this is what we should be promoting now. Time to stop complaining about the cuts (me included :) ) and promote what's great about what we do.
Well we have just had some figures back from our customer that got a 4kW Sanyo HIT 250w panels SMA Inverter fitted on a Deger Tracker and his highest reading which was Sat 26th May 49.8kW WOWZERS Over 3 days last week with the good weather it was regularly achieving 45kW. This is in Stirling, Scotland
What do you think?
  • [ElectriciansForums.net] Smashed it !!! what a result in June so far
Reply to Smashed it !!! what a result in June so far in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
