P
Peter-L
Hi,
I was hoping someone could help double check and clarify some stuff for me. I'm in the process of putting LED SMD strip light under some cupboards.
What I've got so far is -
5M LED SMD Strip Lights - Working Input Voltage: 12VDC, Working Current/meter: 0.4A, Output power: 48W /5 Meter
LED Driver - Input Voltage 240VAC - Output 12VDC, 2.5A, 30W Output
The query is that the only Push to Break cabinet switches I can find are a maximum of 2A, would this be enough to wire 2 (parallel for 2 doors) before the LED Driver?
Any help much appreciated!
Pete
Pete
