Search the forum,
Discuss Smeg A4-5 Access to replace controls in the UK Electrical Forum area at ElectriciansForums.net
I hope this is the correct thread.
I have to replace the main oven selector switch in a Smeg A4-5 cooker. I can't find a proper service manual and want to check about access. It's not immediately clear whether access to the switch would be from the hobs above or whether (having removed the front escutcheon) you release all the fixing screws from the controls (which presumably are mostly then held in place from the rear) and then remove the main mounting plate holding the controls.
Any advice would be greatly appreciated.
Reply to Smeg A4-5 Access to replace controls in the UK Electrical Forum area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi Hope someone could help, I have a Smeg induction range cooker that randomly trips the switch to all the plug sockets in the house but never...
6K
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
