Smeg cooker tripping randomly | Page 2 | on ElectriciansForums
Discuss Smeg cooker tripping randomly in the UK Electrical Forum area at ElectriciansForums.net
Neilacker
England
Hi
Hope someone could help, I have a Smeg induction range cooker that randomly trips the switch to all the plug sockets in the house but never trips the switch the cooker is on, we have had an electrician check the wire from the cooker to the mains and all came back OK and a specialist smeg repair man look at it and no one can find fault.
It will randomly trip doesn't matter whether its the oven being used or just the induction hob, it could trip 3 times per hour then go days without problem a
The model number is tr93ix si 08.
He put some sort of tester on it I remember him telling me the equipment he was using was more accurate than a multi meter
Sounds good.
Coming from a French background i wonder if any of the experts in here (since i'm not one) think it's a reasonable suggestion that the AC RCD could be the problem? I've had a look at the cooker there doesn't seem to be much electronics on it so maybe this suggestion is bunk but i just noticed the AC RCD and it sprung to mind.
Intermittent faults can be a bit of a pest to find sometimes.
They are by nature not always immediately obvious.
It may be that he was unable to replicate the fault as it may be something inside the cooker heating or cooling that causes the issue.
There is also a possibility that it's a neutral earth fault on a separate circuit.
Sounds good.
It'a apparently got an induction hob, so it's got around 7kW of electronics I believe ?
On the back it mentions 11.1kw and 19.4kw
Thanks for the advice.
Little update, I have borrowed another range cooker that has induction hob and electric oven but not has powerful has the smeg (don't know if it will make any difference) just to see how it goes, so far 2 days in and no issues at all i will let you know how it goes over next few days.
Reply to Smeg cooker tripping randomly in the UK Electrical Forum area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
