SMEG large oven not heating
R
rai
Hi
I wonder if anyone could shed some light on the cause of my SMEG DO4 SS-5 not heating up. The fan, internal light and clock are all on but just no heat.
I have read that it maybe the , Thermostat, Cut- Out switch or heating element.
I have the double oven and it is the large clock operated oven which is at fault.
If someone can assist that would be appreciated.
Probably good enough as the rated element @2700Watts will be to get the oven to max temp (usually around 250degC) and that's hardly ever needed. The oven will be thermostatically contolled and not just a simple rheostat!
