if I open the Smiley drop box from the options, it's blank, not a smiley in sight. any suggestions???
Discuss Smileys or no Smileys. that is the ??? in the Electricians Forums Suggestions area at ElectriciansForums.net
I've discovered a way to do it!
The smileys don't work on this site, so you can't just click on the smiley icon above where you are typing (although you used to be able to a short while ago) You can use your own emojis though. I'm using a laptop. Right click and select emoji!
They dont look as good as the site ones though
Site emoji =
laptop emoji =
This is getting very technical.
Reply to Smileys or no Smileys. that is the ??? in the Electricians Forums Suggestions area at ElectriciansForums.net
