Smiths 4 wire low voltage PIR required | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Smiths 4 wire low voltage PIR required in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
One of theses PIRs has given up the ghost on my (very old!) security lighting system. Everyone I've asked tells me there is nothing compatible in todays market, so I'm hoping someone has got an old one gathering dust somewhere.
I'll happily buy more than one if you've got any from an old system.
on you control unit the yellow is the trigger terminal marked T this needs to be connected to the S terminal on the gjd opal, so power and terminal T only not need to connect the P terminal.
GJD opal is a great pir 35m range adjustable range and light light level sensor....see my last post for detailed instrutions and link
Thanks for your help with this tazz. Unbelievably I completely forgot about it, till I noticed the 4 naked wires on the side of the house the other day, then managed to pick up a new Opal for £35 off evilBay. I connected it up as per your instructions and it works perfectly. You dont know how to bypass the low water pressure sensor on a Trition 200e shower as well do you ;-)
Cheers, Andrew
Reply to Smiths 4 wire low voltage PIR required in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
