Smokes? | Page 3 | on ElectriciansForums
Discuss Smokes? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
interlink wire on smoke alarms normally aren`t 230volt. They are just a signal for communication. For this reason different makes of smoke/heat detector can`t be interconnected. I still oversleeve the black thou out of habbit or autopilot.
Hi there
have been trying to get some info on a microfire alarm system and see you fitted one a few years ago. Do you still have any info on how to get the level 2 code. Thanks For any help you may give.
Thanks for reply. The microfire alarm I was on only has 4 buttons on it with a call point as well. Product code is MICROFIREGGP
Thanks.
Reply to Smokes? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
