To be fair here JK you do 'sometimes' find certain precautions being taken to provide 'clean supplies' in studio recording/listening environments. About
the most extreme of these is to run the A/V side off isolating transformers - and from there take particular precautions about how/where your earth reference is established; but that has to do with managing the potential for 'earth loops' - or rather stopping it being 'managed' by random means (i.e random earth lifting on portable equipment) that compromise safety. 'Sometimes' you'll find MDUs (which are often quite complex things that switch things on in a particular sequence) and there may be 'some' filtering in there... Typically an IEC socket on the input with a similar sort of filter' as you'd find on the mains input of a washing machine built in!
But otherwise? No.... It's just not done for the simple reason there is no real reason to do it!
Funnily enough, in the Glasgow area, most of the 'sparklies' once suffered by those west of Blackhill and East of the airport were generated by its radar! The old system was 'filthy' and had harmonics that blighted both TV and FM transmissions across the city for decades; you'd even get bleed (circa 2Mhz) into closed video circuits! And yes, once upon a time there were some generated by 'spill' from things like microwave ovens. - CB radios even and other crap...
However... Your friend is sadly misinformed if he imagines the end of these sparklies are anything whatsoever to do with "LCD filtering technology"... ( you still got them on LCDs with analogue tuners back in the day) It's simply that we are no longer receiving analogue transmissions; that service is closed! - Nor are we commonly feeding PAL analogue signals from crappy VHS players to scrappy TV sets along inappropriate leads - 'baseline' video required a 75Ω co-ax which was VERY often missing from shitty SCART and Phono leads sold for the purpose...
AND ...It's a very long time since tellies were built with 'live' chassis or they were allowed to sell hoovers and hairdryers that sent out signals to the space aliens than hing aboot Bonnybrige; you won't even find spark plugs and ignition coils for your car on sale that upset your 405 line reception anymore! Even Glasgow airport have a new radar system!
Today - We most often hear of cowboys trying to sell overpriced HDMI leads off the back of these mysterious 'sparklies' along with a load of other complete and utter rubbish about their effect of picture quality.
"This is where sensible investment scores with a degree of surge limiting (EMI) Electromagnetic interference filtering and (MOV) Metal oxide varistors within the surge protector.
There should be 3 present with filtering x and y capacitors Cheap ones have one or none at all to assist filtering and to remove noise from the AC sine wave as much a possible before it hits the components own AC filter which in a large amount of cases is sadly lacking, even in many so called audiophile systems."
Whit? Whose wee dug? For a start - Capacitor "classes" have more to do with the rating of the device... Although there is a relationships between that and how they are used as mains filters.
http://www.seered.co.uk/sunvic_capacitor_information.pdf
...Frankly, if the PSU inside your audio equipment is 'unable' to filter out this sort of thing then it's a badly designed pile of crap and just not fit for purpose! It's a part of basic power supply design!
"When it gets in, often through poor quality phono leads and connectors, it will load the signal lines with rubbish which will then be amplified, resulting in clipping and distortion. This causes increased heat on the output stages which in turn will shorten the life of the component."
Ah! the old half-baked conflation game! - Remind me; is this RF coming down the mains or in through ten-bob-a-dozen phono leads from the Barras? And how does a filter on the mains plug end mitigate that?
...It's seriously doubtful whether any AF stage worth its salt (or otherwise for that matter) can or will amplify RF; it's something that 'should' be designed out of the system as it would cause instability! There are other reasons (EM harmonics at AF being directly induced) why very poorly designed/ancient equipment can be affected by things like 'camp on' signals from mobile phones at close proximity - the 1971 ITT Weekend Automatic we have in the kitchen is a case in pojnt. As are the shitey ÂŁ4.99 Asda computer speakers I have attached to my desktop... But I can assure you, even my refugees from the Antiques Roadshow ain't amplifying RF and attempting to drive the speakers with it!
Seriously - Take some time to go through the Canford catalogue. See what they sell and (more importantly) what they don't sell and then think about the fact these guys are the leading suppliers to recording and broadcasting studios in the UK, Europe and much of the Middle-East, Africa, Asia and the Far-East. - This is the sort of equipment the world's most critical professional listening environments have; and which is specified and bought by actual professional audio engineers...
