snipped cpc`s | Page 2 | on ElectriciansForums
Discuss snipped cpc`s in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Roger that GaryM
Just logged read first post and jumped in with both size 10's
didn't view the link same article different site
ESC site has lots of other useful guidance also
Reply to snipped cpc`s in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Given the obvious limited capacity of whoever fitted the switch and who knows what else, I'd be keen to check the "earth" is definitely connected...
A problem putting multiple cores into a ferrule is when you need to do testing or fault finding. You can't just drop the ends out of the terminal...
