Socket in airing cupboard | on ElectriciansForums
Discuss Socket in airing cupboard in the UK Electrical Forum area at ElectriciansForums.net
Kirkheaton
Im currently doing a EICR report they have a socket in a airing cuoboard which used a to have a shower pump plugged now has the vacuum.charging. the distance from the bath is well within zone 2 but is in a seperate cupboard what C classification would you give this?
If cupboard needed a tool to open then that's ok. But I'm not sure it's the same as putting it otherside of the bathroom door ?
With my tin hat on, I'd be tempted to C2 it as if the cupboard door was not there ... BTW, is there an RCD ?
The extent of the special location is limited by the airing cupboard doors
With that in mind the socket location is fine
If on the other hand you were installing sockets and felt personally that you need to account for a idiot plugging an item in an airing cupboard or landing socket and hoovering their hair whilst playing in the Bath then advize accordingly :)
I haven't looked this up, am not disagreeing with the views given and not being near to a set of Regs where does it state zones do not include cupboards.
As far as I know the regs only state that no sockets shall be within 3m of the boundary of zone 1.
I know of no reg that exempts the inside of a cupboard from being part of the special location.
Yes I was thinking the 3m part but the cupboard rang no bells, so from this I would conclude there should be no socket there?
I would conclude this too. Can anyone who posted above who advised no code provide reasoning behind this ? Seems to be a commonly held view so there must be some basis in official guidance at least.
That's knackered my landing socket then. I'll have to remove it :)
Reply to Socket in airing cupboard in the UK Electrical Forum area at ElectriciansForums.net
There is also the ongoing problems if this is a gendered changing room.... For example, 2 or 3 burly male soldiers (you said it was an officers...
ok cheers for the help lads
