Socket outlet with car charger & lawn mover | on ElectriciansForums
Discuss Socket outlet with car charger & lawn mover in the UK Electrical Forum area at ElectriciansForums.net
MNV
northampton
Hi Mate, Any one of you can explaine, why when I installed new socket(BG Integrated RCD protected), it works with car charger and not working with lawn mover. Some other issue is that when car charger not working when connected with extension but it works good with lawn mover.
Mano
Sorry for confused you all. It’s in the garage, I installed new socket outside with same circuit inside the garage. Car charger works only if I connected directly to socket (both inside and outside) problem is now the lawn mover is not working with outside socket which I newly installed(problem is not getting On, RCD is ok), but it works with extension lead directly from inside socket.
Before installing new socket outside, I tried car charger with extension from inside socket and it was not working.
Hope I didn’t make more confusion
Mano
Mano
Where in Northampton
Reply to Socket outlet with car charger & lawn mover in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
You won't fall fowl of anything you are installing a 32A socket it is up to the user how they employ it.
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
