Socket outlets supplied via an emergency trip button | Page 2 | on ElectriciansForums
Discuss Socket outlets supplied via an emergency trip button in the Australia area at ElectriciansForums.net
stever37
I was wondering if any one has installed anything like what I have been asked to do.
It is in a training enviroment and they would like approx 5 sockets installed allong a wall that can have the power switched off via an emergency trip button by the teacher if required.
I was thinking a radial circuit fed via a contactor which opens when the emergency trip sw is hit. Not that experienced with contactors to be honest. If the contactor is N/O therfore requires a supply to keep it closed (which will be the normal state) will this not eventually burn out the energising coil ? Or does a contactor `latch in`. Was thinking of the control circuit via the emergency trip sw with N/C contacts hence when operated de-energises the operating coil of the contactor thus de-energising the radial circuit. (But concerned about burning out the operating coil)
I am on the right track here ?
I had to do a job once where they wanted an emergency button which when operated, energised a normally closed relay, which then opened, thus breaking the power to all the various bits of equipment.
Ther were a few red faces when i pointed out that should the mcb controlling the emergency stop circuit trip (yes it was a different one) , and nobody noticed... then the emergency stop button will become useless.
Hard to believe people paid far more money than I, can come up with this crap.
Reply to Socket outlets supplied via an emergency trip button in the Australia area at ElectriciansForums.net
