Socket ring main causing flickering lamps | Page 2 | on ElectriciansForums
Discuss Socket ring main causing flickering lamps in the UK Electrical Forum area at ElectriciansForums.net
Lancashire
Hi all
To start off, there’s been no work on the ring main for 8 years or so. (Other than having a smart metre fitted about 12 months ago)
Yesterday afternoon I noticed a buzzing from a plug socket. I unplugged what was plugged in thinking it was the appliance and didn’t think anything more of it because the buzzing stopped.
Last night switched on some lamps plugged into other sockets but on the same main and they started to flicker. Going around the house, things flickering on that same circuit. Even a fused switch, the little red light was flickering.
I reduced what was plugged into the circuit and the flickering stopped. It seems it can’t take more than a couple of items plugged in.
We have 2 ring mains for the circuits and the other is not affected so I don’t think it’s the supply. Yeah
So, seeing this is something that has just started without anything being messed with, could it be the RCD needing replacing?
The RCD hasn’t tripped. I’m thinking seeing it’s not 1 socket causing it, the short could be on the board.
Any advice of where to start testing would be very much appreciated.
Chris
Reply to Socket ring main causing flickering lamps in the UK Electrical Forum area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
