Socket & See tester | Page 2 | on ElectriciansForums
Discuss Socket & See tester in the UK Electrical Forum area at ElectriciansForums.net
Dannydandan
Evening,
I use a Socket & See tester instrument to provide a means of confirming safe isolation before working on boilers.
Can anyone explain why I am required to press the touch pad at the bottom of the test instrument in order for it to perform a polarity test?
I understand what polarity is and why I'm testing it, but I don't understand what the significance of this pad is i.e., what does me pressing the pad actually do to the test instrument?
I've asked colleagues and trainers but no one can answer this question!
Many thanks,
Dan
Sounds like it works in a similar manner to a neon screwdriver.
Yep,you can get them brighter,at the end of a hard,sweaty day...
The previous Megger TP voltage tester,had a touch pad,at the rear of the handle,which is omitted on the new model.
The voltage <than,>than,seems superfluous,as <203 or >253 could be a problem,or installations where no problem has been noticed.
Reply to Socket & See tester in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
My older card has it but my newer card doesn’t
