Sockets in bathrooms | on ElectriciansForums
Discuss Sockets in bathrooms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
How long before BS 7671 allows socket outlets in bathrooms
  • Amendment to 18th
    Votes: 1 5.9%
  • 19th
    Votes: 5 29.4%
  • Never - far too dangerous
    Votes: 11 64.7%
  • Total voters
    17
  • Poll closed .
wheeto
A friend of mine has installed a BS-1363 socket in their bathroom, well outside of the zones (but not 3m outside) and protected by a type A RCBO which is itself downstream of a type AC RCD. The friend installed the socket in a 40mm back box, and when (s)he moves house and gets an EICR, the socket will be replaced by a BS-4573 shaver socket.
This got me thinking: do we think 7671 will ever permit 1363 sockets in "Locations containing a bath or shower"?
In this room, the current regulations prohibit socket outlets unless they're at least 3m away from the bath and the shower. I wondered what members thought of the future, though?
I think the issue is not just "Can water / wet hands touch the socket?" as much as "What will a future moron will bring in, plug in, and perch on the bath side?"
Of course an RCD ought to cover most of that risk, but RCD are not infallible and a good wet connection could result in a very high current before the RCD disconnects in tens of milliseconds.
Maybe the regs will update and stipulate IP69 RCD sockets being allowed? Covers the RCD side and the water ingress issue
There's no reason /need it should ever be changed.
Unless the London Fire Brigade produce evidence to prove not having sockets within 3mtrs is a danger.
Interesting thought, although I don't imagine that water ingress into the fitting is really the issue.
Neither do I but it would tick the boxes, was more for the RCD protection than anything so if you did get someone with a distain for life and wants to bathe with Talkie Toaster, you have the additional RCD protection
[automerge]1591996815[/automerge]
Why LFB? or just LFAs in general?
From a layman's perspective, I'd be inclined to view this in terms of benefits weighed against potential risks.
My parent's house used to have a 5A socket fitted to the bathroom ceiling, close to the door. They used to plug a night light into it and no one ever came to any harm, but that socket recently disappeared along with the perished VIR cable that brought power to it.
It already does allow sockets in bathrooms, and not 3m from zones but 3m from zone 1. So, it can't be within 2.4m of the bath or shower.
[automerge]1591997930[/automerge]
I have a socket outlet within 1m of my bath tub, it just happens to be on the landing.
You have a bath on the landing? :)
I don't understand what you would want a 1363 socket in a bathroom for?
With my sensible head on - realistically it would appear ok for things like phone chargers/radio/tech and so on as some people will relax in a bath with media playing or gaming I guess.
Beyond that, I don't think anything should be connectable within the 3m range.
A rcd will be of little use, as soaking wet, even a few mA will be able to pass direct through the heart; whilst when dry (ish) the actual current through the vital organs would be reduced and the operating time does allow reasonable protection.
So I don't think there should ever be allowed the use of any 230V outlets within the 3m
However, I do think a new type outlet should be designed and approved for within this zone, and that would effectively be a USB port - having similar isolation as the shaver outlets
So people won't be inclined to run extension leads for phone/tech chargers into the zone!
Reply to Sockets in bathrooms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
