Sockets Keeping Tripping Help... | Page 2 | on ElectriciansForums
Discuss Sockets Keeping Tripping Help... in the UK Electrical Forum area at ElectriciansForums.net
Chezza
South Yorkshire
Hello, and thank you for reading.
I am having a problem with my sockets in my house both upstairs and downstairs.
It started with the hoover, it was tripping out in various sockets intermittently. We thought it was the hoover so bought a new one just in case. However it stopped tripping out so carried on using it.
Subsequently my washer (3 years old) not integrated just stand alone also keeps tripping out at various stages of the wash.... so we tried the plus above it on the counter top - same tripped out. We've also tried running an extension lead into the living room and it also cuts the electricity out. So its not the socket. We thought it might be the machine, until we plugged it into a socket near the phone line and it worked (hubby reckons this socket is linked to something else).
Yesterday my steam generator iron tripped the electric in a socket upstairs...had to use the travel iron for school clothes! cant use the steam iron because it will trip the electric in any socket in the house bar the front room one the washer went in.
This afternoon, my soup maker tripped the electrics. Its a Morphy Richards one like a kettle....works the same way then blends loudly.
However...…
My fridge, Fridge freezer, kettle, toaster, microwave, electric oven, computer and printer seem fine, as does my central heating pump timer.
I'm at a loss as to what it could be....its not a particular socket, or a particular item....
On my electric box, its the socket switch that keeps going down, however my house lights also go off but the switch for them stays up.
Can anyone help me? offer advice? been in a similar situation?
thanks in advance....
I am not sure what an EICR would achieve, although it may be due to have one. The O.P. stated there is some sort of fault the employment of a competent electrician with the correct test equipment should be able to find the fault if it is the fixed wiring. Have you tried to unplug and switch off appliances and see if it still trips. As been posted a photo of the consumer unit indicating what trips off would be helpful.
Sorry Ant with the quick reply I assumed it was you who disagree how wrong was I? sorry Mate.
Well an EICR clarify the condition of the OP's installation, nullifying the need for changing bits here and there, or do you disagree with that as well?
I'm not sure where I said about agreeing or disagreeing about changing bits? I thought that the OP would want an electrician to find the fault or reason for the protective device (MCB,RCBO or RCD not specified) tripping out. An EICR is only that a report and involves more than identifying there is a fault. Depending upon the initial fault finding an electrician may recommend an EICR.
pete, i tink dave gave a disagree on your post advisinf a EICR, while that may be a good plan, the nub of the matter is more liek a fault investigartion,
Hi guys, we think we have found the fault. My daughter has a light on her desk in a bedroom. This is on a double socket. The light switches on and off okay but when we opened the socket (electricity off) it revealed that the black wire was burnt! It is this that is tripping everything off. We’ve unplugged the light and made the light safe until tomorrow when a local electrician can have a further look.
Currently the washer is running at the moment with no faults after causing so much trouble for the past few days.
Thanks everyone for your responses
Nice one!
Get a new socket fitted.
Reply to Sockets Keeping Tripping Help... in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
Which rcd is it? Is it one for everything, one for a few circuits?
