sockets tripping at night | on ElectriciansForums
Discuss sockets tripping at night in the Australia area at ElectriciansForums.net
c.boy
Scotland
Hi all
Got a call about a fault. The problem is that the downstairs ring keeps tripping at around half 10 every night. My ??, is there some sort of part that kicks in on the freezer at nights??? Seeems odd that it happens at the same time every night.
thanks any info would be great
WONDER IF HE SAT IN THE HOUSE TILL IT TRIPPED LOL
SOZZ for caps oops Had a fault like this years n years ago power would trip after lunch we ended up going and watching what happened as when the lady called n we attended tested everything was fine
she got up made a coffee for her and one for her bedbound husband then another for them both before filling a flask for him she then went to work came back n made them both a coffee n lunch then made herself a coffee n TRIP it was so simple the kettls spout was pointed up under the units and the condensation was running down into the socket building up over the day and tripping the rcd of course the time we took between call and attendance the condensation had dried out n Irs were ok Turned kettle spout round all ok
Hope its a simple appliance fault for you Cboy
could be the condenser on the freezer,i had similiar problem
Went today and buzzed out out the ring .36 for live and neutral and .61 for earth I/R >299 r1+r2 = .22 interconnected L1 TO N2 and all that was fine also!! My original ? was that is there something in a freezer that could trip it out??? Its my mates dad so i have told him to un plug tbe freezer from 9 till 11 and see if it is this as all other equip is dissconnected!!! How can u test a fridge foe leakage anyway???
many thanks
Auto defrost on the freezer, a heating element kicks every 24 hours for the defrost cycle if this is faulty it will trip the RCD. It is normally quite easy to disconnect the element if this is the problem while you source another element
Had this problem a few times
Reply to sockets tripping at night in the Australia area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
