sockets | Page 2 | on ElectriciansForums
Discuss sockets in the UK Electrical Forum area at ElectriciansForums.net
So if Mr Customer knows so much why has he asked you to do the graft? There's nothing to stop you doing this but I'd resist it as much as possible because you could end up with 2 different circuits serving a similar purpose in one area.
Even then, I think you'd struggle to find anything to prohibit this. I just think it's inviting problems.
Well I agree with trev - best to do it 'properly'.
Others might argue that if you don't do it as easily and cheaply as possible then Kev from down the pub will, but I like to have standards.:49:
Assuming this is a reference to our discussion on Aerial boosters recently, I assume this is aimed at me. I think questioning my standards is at best misguided and at worst disrespectful. Sometimes doing the most cost-effective job (that is safe, compliant and neat) is preferable to chasing out walls unnecessarily.
I did something similar with an extra socket today so I could use an RCD protected way and clearly marked it on the CU.
It's for a regular customer and a CU upgrade is on the cards in the future so will be able to sort it then.
There is kind of an argument for not having all the sockets in one room on the same CCT in case of a fault, but it's not a very good one. :)
It was in reference to that thread, but not specifically aimed at you.
Cripes - how many houses in the UK have sockets in 1 room, served by 2 or more circuits? or more!
I think the OP needs to determine exactly where the cable is connected and go from there - for all we know if could be connected to the CCU!
Reply to sockets in the UK Electrical Forum area at ElectriciansForums.net
Well we called it a room, but it was only a hole in the ground covered with bit of canvas.
As long as you can carry out all the necessary testing, certification, are insured to do the work and all is carried out to Amendment 2 of the regs
