Soffit lighting | Page 2 | on ElectriciansForums
Discuss Soffit lighting in the UK Electrical Forum area at ElectriciansForums.net
Rotherham South Yorkshire
I had someone ring me up yesterday regarding installation of some soffit lighting on an external garage. I'm going to look at it over the weekend however I'm just wondering if anybody has done this before and what they have installed? I'm swaying towards just fitting some led spots. I did think about a decking light kit though but it may not be bright enough? Also need to see how he wants them switching e.g pir/on a timer/manual switch.
Hi Murdoch was thinking of using one of these Steinel sensors, have you fitted a few of these before? Is it a simple mount to the external wall with cables routed through the back of the unit? Any advice much appreciated, this is my first post/reply on the forum.
Reply to Soffit lighting in the UK Electrical Forum area at ElectriciansForums.net
and sometimes if the drainpipes have been up a while the brackets can be brittle from sun damage and as you say they are nailed on which can be a...
Have had the issue of led lamps still glowing gently when switched off, snubber worked a treat on more than one occasion 👍🏻
