Soffit lighting | on ElectriciansForums
Discuss Soffit lighting in the UK Electrical Forum area at ElectriciansForums.net
Uddingston
I have never installed downlights in a soffit before and have been asked to do it.
New build house. Is it a case of drilling the holes in the soffit and fishing the cable into the loft or is there more to it ?
i fitted non-fire rated, not ip rated, cheap and nasty, downlights in our soffit 7 years ago. they ain't rusted, not caught fire, not fell out. aint even replaced a bulb.
I was asked to fit soffit lights in a bungalow once. Looked pretty easy at first. Measuring up and marking for the holes...yup, asbestos soffits! Homeowner was completely unfazed, got a specialist company in to remove the asbestos, new soffits installed and got me back before completion so I could run the cables in. Asbestos man = £1200,
me, £200....
me, £200....
If you do the "working with asbestos" course and pass it you will find that ensuring that you use suitable equipment and take the required precautions drilling into the asbestos can be achieved. Obviously removal is always going to be the preferred option, but being asbestos aware, especially in our trade is a huge benefit!!
Pretty much, make sure the downlights are suitable for damp locations or they will rust badly.
I have the Integral Evofire series which are made of steel while IP65 rated (for Zone 1). Do I have to worry about rusting in that case? Say, for average contemporary downlights, is there a chance that the coating corrodes over time?
They will all rust eventually, but IP65 should be good for number of years. Not sure about more decorative ones but many now use plastic rims with a metallic finish so no rusting there.
That's frustrating... The plastic ones seem to only exist as integrated LED cans while I'm looking only for GU10 ones that could ideally last longer. Might aluminum ones be better at this (e.g. JCC Fireguard)?
Ansell make a downlight specific for soffits. It is Du Pont paint coated and guaranteed for 20 years.
However the best thing about them is that they are tiltable which can be very beneficial as shining lights directly on plastered walls can show up any defects in the plastering. Additionally as they take GU10 lamps you make them as bright as you wish
Thanks a lot for the suggestion. I'll consider these for my balcony indeed!
You could have a try asking the OP if those he used were up to it.........seeing as it's
4yrs back.
Reply to Soffit lighting in the UK Electrical Forum area at ElectriciansForums.net
and sometimes if the drainpipes have been up a while the brackets can be brittle from sun damage and as you say they are nailed on which can be a...
Ok I’ll try this when I’m down
You too? I thought I was in a unique position:anguished::coldsweat:
I guess my last post was even less direct than intended.
nicebutdim
N
I doubt we would be recommending them if they were not up to the job
