Soffit lights, only problem is soffit is concrete | Page 4 | on ElectriciansForums
Discuss Soffit lights, only problem is soffit is concrete in the Lighting Forum area at ElectriciansForums.net
And here are similar vintage properties on a neighbouring street
our gaff (1950's build) has almost identical concrete inserted into the outer brickwork.the soffits, however, are apparently asbestos. a closer look will show the difference in thicness, the concrete is roughly 2 ft. long, 6" in height, and 4" width.
from this angle you can clearly see the extent of the concrete. the actual soffit is only about 1/4" thick.
[ElectriciansForums.net] Soffit lights, only problem is soffit is concrete
It's a cast in-situ concrete ring beam - it ties the top of the brick/blockwork together and is the landing pad for the roof timbers.
Dont be tempted to fix anything to it, or drill/core through it.
Reply to Soffit lights, only problem is soffit is concrete in the Lighting Forum area at ElectriciansForums.net
Hope you get better soon .sounds quite serious
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Thank you... I'll get up there have proper look, this was just a 1st glance !
