View the thread, titled "Solar Business" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
Mozzer
For a Pv system sounds like you have had a bargain even with this material did you play one off against the other to get that price
Hi DP,
Totally agree we are mcs and didn't realise what criteria was required what a load of tosh
If you want maybe we can do your stuff for you!!! We do have another company wanting us do there installs
Too. Might as well make the most of getting mcs registered as our filling system looks like a government office lol
lightgen
you sum it up perfectly we are solar installers and doing everything right!!! but the publicity you talk about has put people off .
If the government had not changed the fit rate and there were no free solar or mis use the economy would have been kickstarted again quicker instead panick from the government caused chaos and those people behind the free solar nonsense. who are the people behind the free solar??
if/when given monkeys, I make damn sure I do my best to keep an eye on 'em...
You are a versatile man, a monkey keeper, as well as a savvy solar buyer.
One simple question:
Why didnt you choose better quality solar panels out there given your savvy solar ability?
Better quality solar panels would have increased your solar FITS earning potential per annum by 16-28%, over 25 years. If this additional FITS money was invested annually, this would make a massive difference over 25 years.
To me Solar is a slow, incremental energy creation generating scheme for the long term.
Not a get rich quick, double your money "overnight" scheme for the greedy.
Those that look at long term earnings, with quality, suitably oriented, well designed solar systems, designed to last, outperforming similar systems in their area, with decent warranties or backup should your system fail, those are the true solar savvy customers.
People bragging on forums, going for cheapest first, that have inflated ego's / opinions of self worth, which fail to do sufficient homework and worse still encourage others to ditch quality, in the quest for price. These are the people to avoid.
They will be the people coming back in 7-10 years time bleating about their solar install, expecting advice from "neutrals" about how to repair failed solar inverters, or solar panels with diminishing returns after their solar manufacturer has gone bankrupt.
Do your homework when buying a solar system.
Don't be seduced by cheapest is best.
A 16-28% solar loss will prove significant for Mozerr over 25 years.
...even with this material...
The panels are insurance backed guaranteed, the SMA 4000TL inverter has the manufacturers extended warranty and the installation/workmanship has an independent warranty insurance. Don't know what brand the roof fittings and rails are but I was up on the roof while they were being installed and I'm happy with their quality. Even had them replace 3 cracked roof tiles which were already broke, not by them during install!! So not sure what other sub-standard "material" you are alluding to?
...did you play one off against the other to get that price...
Had a total of ten quotes, only 3 of which actually visited the house. You learn as you go what's required - then no point in wasting mine or other's time once you know what you want. Obviously basing the price negotiations all on one 4Kw install, then introducing the requirement for two identical installs close together had the benefit of certain economies of scale.
Compare these 2 systems:
Compare
Better quality, more expensive solar panels will reap extensive dividends over 25 years, compared with cheaper, poorer quality ones.
Cheapest is not always best.
A 19% solar gain will be significant over 25 years, especially if the annualised proceeds are reinvested.
LOL.. All fair comments from Veggie, but you can't really compare two systems with so many variables to contend with...
Whatever, I'm happy with my total 8Kwp for what it has cost.
The fact that some have chosen to see what was intended as factual data to aid the OP in his decision as "bragging" is a bit of a shame IMHO. Perhaps they should get back to updating their daily generation figures on the other thread - which seems to have degenerated into a "who can pee the highest" competition.
Mozzerr should be congratulated on installing 8KW on 43.3p FITS.
In time he'll do well, regardless.
I was just trying to say "Cheapest isn't always best".
Many people, focus on price at the expense of performance / quality which is shortsighted.
Solar panels need to match the typical weather environment they are installed in.
In NW England, the ideal panel would perform well in low light and bright light conditions.
Many panels do one, or t'other but seldom both.
Compare
sorry, but this is a rubbish comparison.
One is facing south east, the other is south facing, which would be enough to account for the vast majority of that difference at this time of year, plus they're 50 miles apart.
One is also presumably single string and operating at the peak of the inverters efficiency range, the other dual string and operating significantly below the inverters efficiency range.
Do you have any better evidence for your 16-28% improvement claim? Somehow I doubt it.
The only thing I am going to say is be wary of insurance backed warranties, as I have found most are not worth the paper they are written on but most think well its insurance backed so I must be safe.
A number of the chinese manufacturers pay a yearly premium for the insurance and if the premium is not paid then no insurance, there are insurance policies out there of which we looked at adding on to our packages that cover every eventuality including loss of earning, but when put forward to customers they prefered to take their chances.
However coming into light that 40% of large manufacturers may hit the wall in the comming months they may reconsider their position.
A premium for irrevocable insurance over the life of the panels is extremely expensive and only a few chinese manufacturers do it.
Agreed Gavin A. The comparison could have been better.
I still hold the view that buying cheap solar panels over time will prove to be an expensive mistake.
I've looked at hundreds of solar systems on PVoutput.org and there is a large variance in the results people obtain, when combining different invertors, different panels, different roof orienatations, gradients etc.
The bottom line is how much energy does your system create, to maximise FIT returns?
Thats why most people put them there.
If your system isn't reaching optimum generation, individuals wont be maximising their solar potential.
As you are more of a solar expert than myself, please could you help educate individuals on this forum.
What inverters, solar panels etc do you trust and recommend?
Many people reading these forums are interested in installing solar systems with the best performance / price / reliability characteristics available.
Vegelen,
You may be suprised to find there is not one panel / inverter choice that suits all for optimum performance, I have found I can design a system in portsmouth that give optimum output compared to another array, however in newport the other array performs better than that in portsmouth.
size, orientation, pitch, etc will determin different panels / inverters for different customers so this is where learning your products comes in along with PVsol, PVsyst design knowledge with basic understanding of average generation through maybe PVGIS or Climate SAF as a bolt on to the standard sap calcs.
Variation in local ambient temperature too.
Evidently, there are lots of variables in each installation location.
But some solar panels and inverters are better choices than others.
If they weren't everyone would go for the cheapest possible, which they dont for good reason.
And if installers told you their configurations and the reasons why they use the configurations on the forums they would be giving away their hard earned knowledge which at the end of the day is just as important as the configuration itself.
I am happy to tell customers why a specific configuration is chosen for their house but I would not then tell the competition those reasons.
Reply to the thread, titled "Solar Business" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
