G
GaryM
As I understand it, the 6mm2 cable isn't protected by a 63A OPD as I understand, it's connected with other incoming tails from the meter at the terminals of a main switch in another consumer unit.
From there it supplies a 2 way CU with a 63A RCD main switch. The consumer unit has two circuits, one 16A and one 6A. Considering that overload protection can be at the end of a circuit I reckon the 16A and 6A MCB's will provide suitable overload protection for the 6mm2 cable as the maximum demand of the consumer unit and cable will be 22A. As long as the cable is protected against fault current then it's safe enough.
I used an example above of a 400A busbar feeding multiple 63A switch fuse isolators. I can guarentee that the supplies to the isolators won't be rated at 400A.
There's more than one way to skin a cat.....it just doesn't mean that all ways are wrong, just different options of getting the same result.
