solar edge inverter and feed in tariff meter dont match | on ElectriciansForums
Discuss solar edge inverter and feed in tariff meter dont match in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Great Britain
Recently had fitted Solar Edge and notice their monitor gives a reading but the meter used to obtain my feed in tariff gives a lower figure and this is the one I am paid on not the solar edge inverter.So why the difference? this could cost a lot of money over the years.
can you post some figures?
I am thinking along the lines of not all the electricity you generate is fed in to the grid, some is used on site.
My generation goes through the generation meter BEFORE it is fed into the CU and distributed around the house if needed. The generation meter also does not match the alleged output of the SB3800 inverter in the loft and is around 1% lower.
Have a look on pvoutput for systems local to you and see what they are producing.
I'd say the Generation meter is far more accurate than the monitor on the Solar Edge.
Is this Domestic, I thought the feed in payment was a calculated fixed payment, not derived from the Generation meter?
If I understand you right, I think the difference in the readings is because of the losses in the cable between the inverter and Meter.
I'm having (somewhat) the same type of discrepancy. But the main difference for me is the inverters feed into my main electrical panel (after some cut-offs). The electric company net meter is on the other side that also feeds to the same main electrical panel. The electric company is reporting my consumption, generation and difference (net.)
The inverters and the electric company net meter is not consistent nor does it seem to be off by a specific %.
Example: (it's been very cloudy and rainy these last couple of days and I do not have older data)
Inverters reporting:
Jan 15th:9.97 kWh total generated
Jan 16th: 2.73 kWh total generated.
Electric company net meter reporting:
Jan 15th:8.53 kWh - Difference of 1.44kWh
Jan 16th: 0.42 kWh - Difference of 2.31kWh
(also showing me the totals for consumption, Generated and net)
Would the house be utilizing the power without the net meter seeing it? and/or the Inverters ->shut offs ->panel ->wiring -> net meter connections be losing the difference? (or the combo) (which that is too much too lose in just connections)
Essentially can I trust what both the inverters are saying they are generating AND what the electric company net meter is reporting?
I used to be an aircraft electrician for many years. But since I've never dealt with this type of issue, I'm hoping someone can verify my list of possible causes or make a suggestion: (house using some, net meter not seeing it) and/or (power loss between all the gear ) or this type of difference is normal? or suggestions to check?
Thank you!
Reply to solar edge inverter and feed in tariff meter dont match in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
