solar flash | on ElectriciansForums
Discuss solar flash in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
marc8
Essex
hi has anyone used solar flash system on slate roof?
can anyone recommend a roof hook for the above needs 30degree offset as it comes of room rafter?
talk to andy at sibert about the genius roof solutions slate flashing kits they sell, they also sell mounting kit that works with it... sure he'll be along shortly anyway.
Hi Marc, we do stock the Solarflash and suitable roof hooks, drop me your contact details (andy dot oleary at sibert dot co dot uk) or a PM and I'll advise details if you want
thanks sibert
but roofer we use wont drill slates he normally dresses with lead makes everything up, but i think
now we are going for solar flash this should make his life a little easier & my pocket a bit better.
Reply to solar flash in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'm looking for advise on the type of mounting system suitable for these types of tiles. These are sort found on new build houses. They are...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
