Solar iBoost died
I didn't. I replaced a glass fuse with a glass fuse rated identically :) admittedly it was a slightly larger glass fuse but it was rated the same. Admittedly ive done many silly things in my time. To be fair though on this occasion tested all the component's I could first with a multimeter having taken the unit off the wall. I used a phantom power supply to test the led circuit to see if it lit up when I put the fuse in. It did. It wasn't attached to the mains electricity supply. I did fully expect it to blow again when I reattached it to the mains but it didn't. Both it and I survived but I would not advocate anyone else doing it as my level of controlled silliness may not be matched by common sense in others. Thank you for your concern though :)
That’s good information. Any chance of pictures to show where the fuse is you have replaced.
im in process of getting solar iboost. It’s a need to know thing.
Not from me I'm afraid. It's inside the unit... its one of those " open here to void the warranty" things. Mine was out of warranty anyway. If you open the unit the fuse is pretty obvious but it's not supposed to be "tampered" with so be aware.
mine was £200.00 secondhand and 2 years old. It worked very well for almost 10 days..then BANG.
Trying to repair it is probably a lost cause but hey...
A better route [in my opinion] is get as big a battery bank as possible so the DHW immersion can be turned on at anytime....hence I just ordered a 50+kWh brand new 48V Lead Acid battery pack....5 years guarantee...that'll be better than trying to get an iBoost or Eddi or Zappi to work on modulated solar.....it can all just bung straight into the battery. ..still, it seems a waste not to fix the iBoost.
Maybe they changed the design to a glass fuse cos the ceramic was too strong? . Mine was clean just blown??
It's the other way around, a ceramic fuse will handle higher fault currents than a glass fuse.
Ceramic fuses are filled with sand to absorb the molten metal and quench the arc.
Indeed. I bought mine new about 7 years ago. Also have solar with battery but any unused goes to the grid. Hence putting the water unit in. Wish I could find a switching system so I could charge a second battery bank once the first is full....
£4500 for the battery £350 for solar iboost.
would it be viable?
I think that's what I'm saying. The higher fault load handled means the ceramic will be hotter and so will be more messy when it blows where the glass one will blow at a lower fault and only the wire will melt... that's how it seems in my head anyway...
All brand new kit: £7054.00 for 48v 1200Ahr @C20 and 11kVa Hybrid inverter and auto battery watering kit.
Bought from Paul Byrne of pbbatterysolutions.co.uk
I’ve dealt with him in the past and he’s top drawer. 👍
