Solar immersion controller | on ElectriciansForums
Discuss Solar immersion controller in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
bill01803
Devon
Can someone recommend an immersion controller that turns the immersion on when the is excess power from solar panels.
I have an iboost+ and it does seem to work well, however my immersion heater is too short, so really I need the heater swapping for a longer one.
I found I needed to adjust the point where it kicks in, seems the CT coil was too close to another CT coil and they were interfering with each other, but the adjustment seemed to work and I think one does need one where you can fine tune it to your system.
Considering what it does it is compact, it seems it can vary the energy used from around 100 watt to the full 3 kW did not know any other makes existed.
Reply to Solar immersion controller in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Controllers that are intended to control twin immersion cylinders only allow one to be powered at a time.
Oooo I think you have demonstrated why it doesn't pay in the end to DIY something dealing with power there mate, to be frank! You had any solar...
