Solar maintenance/repair - Enphase micro-inverters | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss Solar maintenance/repair - Enphase micro-inverters in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Wales
I am looking for someone with experience of repairing solar systems fitted with enphase micro inverters. Two of my inverters have stopped reporting and need to be checked. The hardware is within warranty but their warranty only covers parts.
I am near Swansea and the system is fitted on a bungalow so is accessible
Ha. Great warranty.
Also, on a related subject, Fitted Solar Edge monitoring modules once on a system. They mount under the panels. 6 months old one of them had an insulation fault and lost the whole string. Inverter showing earth fault. Had to rescaffold at our expense. Solar Edge wouldn't even send a replacment until they had theirs back. Think they would have wanted it for R&D......I threw it in the bin lol.
Anyway, as you're in a Bungalow. Do it yourself. Turn off the AC isolator and then the DC isolator/s which will be by your inverter. They will be labelled. Then get on the roof and unbolt the panels. The connectors are pull apart, use your thumbs to press in clips. Replace them units and switch back on DC first then AC.
To be fair the main warranty was with the installer who has gone out of business. These are individual inverters mounted under each panel so there is no main inverter. I am afraid my ladder climbing days are over but I have found a local installer now - just waiting for the replacements. About 6 months ago I had the panels temporarily removed to allow for re-roofing and I suspect that the additional handling has made them more tempremental but I can't come back on the person that did it as it all worked fine for several months afterwards. I went for this as the system keeps working should one inverter fail and replacing one of these is allegedly a lot cheaper than a full size inverter - though they were more expensive to buy in the first place!
Cool. To be honest though, I know you have micro inverters.....but 3.5 - 4 kw inverters are cheap enough now and very easy to swap out. Not sure what size system you have. Even if they do fail early. Found Power One Inverters failed a lot. Most by 5 years. The SMA stuff soilders on though. Over 7 years on a a lot of them and no failures. Never had a single panel failure either. Quality install work I'd say haha.
Reply to Solar maintenance/repair - Enphase micro-inverters in the Electricians Jobs area at ElectriciansForums.net
Solar PV preventative maintenance contracts. What do you guys like to include (and exclude) when putting together preventative maintenance...
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
