Solar panel positioning | on ElectriciansForums
Discuss Solar panel positioning in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
magnoliafan89
Hereford
Hi guys I would post this in the relevant section but it seems that doesn't get much action as in this thread so sorry. But I was wondering on a new build if the roof that is to have the solar panels is facing dead east is this worth it? My understanding is south facing is best failing that south East.
Many thanks for any replies
East is fine as it receives morning sun and high mid morning sun. The site topography plays a large role as well. East or West would be my choice as it gets the longest duration of solar radiation.
edit- It could also be a planning condition
Topography- the arrangement of the natural and artificial physical features of an area. Can be linked to contour lines(not makeup) of hills or a general term that applies to a buildings surrounding environment.
South facing will ultimately generate the most. East/West split will generate for longer so you can benefit from that if you are at home to use it.
It works for us as we are out all day.
Split the array on both sides.
It will see the sun for longer.
Speak to a pukka solar company on here. I used Medoria, he was great.
Reply to Solar panel positioning in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
Are you sure they are back-feeding and not a legitimately grid tied system or systems with an island mode. Whilst the term is not strictly defined...
davesparks
