Solar Panel Power Mains Feed Requirements | on ElectriciansForums
Discuss Solar Panel Power Mains Feed Requirements in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
K
Ken Davison
I have a single phase power supply and a 40 degree south facing roof 14m x 7m plus other options for uv panels. Been researching through several companies and the last one brought up the subject of a requirement for three phase power supply.
Could anyone advise on this please.
you have automatic permission to connect up to 16amps per phase, so 3.68kW AC output on single phase or 11kW output on 3 phase, so they're referring to the idea that if you had 3 phase you could automatically connect a 10kWp system to the grid without needing to obtain permission.
However you may be able to connect this on single phase, you or the company need to ask the question of the DNO via a G59 application, only at that point will you actually know what the situation is, and can then take an informed decision.
Firstly though you need to be sure how much you want to spend, and if it's even worth making the application. No point if you can only justify a 4 or 5kWp system in the first place, either of which can be connected on a standard 16amp limited inverter under standard G83 rules.
Reply to Solar Panel Power Mains Feed Requirements in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
Hi There How did you get on with your basement project?
